MCS-7845H-2.4-ECS2 UID LED Turn On
yewting
I'm using the server mentioned above for the Cisco Unity 4.0.3 After several weeks, the Blue colour LED light is turn on.Maybe I know what's the light indicating? Pls advise. Thank you.
jasyoung
Level 7
Level 7
It's nothing to worry about. The light is an indicator to help you find the right server if it's located in a rack with many other identical HP/Compaq servers. I believe it can be turned on and off with the HP/Compaq management software, but the easiest way is to simply press it -- the blue light you see is also a button, both on the front of the server and on the back. There is no problem at all with doing this while the server is running.
jasyoung
Level 7
Level 7
Thank you for the prompt reply.
