Message notification for analog phones connected to fxs gateway
Jason Pennell
Level 4
Level 4
We have an ICS 7750 with a 16 port FXS MRP gateway configured using MGCP. CallManager is version 3.2.3 and Unity is 4.0.1.
I know that ATA-186/188 devices and VG-248 gateways provide the options for stutter dialtone or MWI to indicate you have a message on an analog device.
Is there anyway to get that work on routers or MRPs with analog devices plugged into the FXS ports?
Thanks in advance for any help.
Markus Schneider
No, unfortunately there's no such capability for IOS MGCP gateways.
Thank you for your response. I'm curious though as to why there is a stutter dialtone timeout command and when I do a show mgcp profile it lists the timeout setting for stutter dialtone. Is it referring to something other than MWI?
Thanks a lot
