MGCP fallback with 7912 and 7920
x.thomas
As you can see on this link :
http://www.cisco.com/univercd/cc/td/doc/product/access/ip_ph/srs/srst32/srs32spc.htm
the Firmware for the 7912 can't use for the 7912 and for the 7920 firmware you can't find it int the Cisco web site.
So for the 7920 and the 7912 which is a real "up to date" firmware for the MGCP fallback that we must use.
Thank you for you help !!!
wong34539
Level 6
Level 6
The following should work with CCM 4.0 phone loads with SRST, but prior phoneload versions should be backwards compatible to SRST.7960/40: P00306000100
7902G: CP7902010300SCCP040312A.sbin
7905G: CP7905010300SCCP040312A.sbin
7912G: CP7912010300SCCP040312A.sbin
ATA: ATA030100SCCP040408A.zip
