07-10-2016 06:00 AM - edited 03-13-2019 09:32 PM
I have a requirement to setup customize MOH for 3 different device pools. Each device pool contains around 200 phones/user profiles. I didn't see any particular setting in device pool to change the MOH, only place is phones/user profile. Then I have to use bulk admin tool , do i need to reset the phones to apply new MOH settings? what is the least impact method to change the MOH?
Suchira
Solved! Go to Solution.
07-10-2016 09:14 AM
Hi Suchira,
Yes, you must have to reset phones to get them updated, so may reset IP phones by reseting corresponding device pools.
MoH Audio Source cannot be set on the device pool level .You can assign the Audio Source at 4 levels :
Line(Highest Priority)
Phone
Common device Configuration
Cluster wide service parameters(Lowest Priority).
The call manager 1st looks for the audio source in the line level ,if that is set to none ,it checks the phone level ,followed by the CDC and the cluster wide service parameters.
If you want to assign the same Audio source to a number of phones ,create a common device configuration (Device->Device settings->Common device configuration) and assign the common device configuration to all the phones that you want to play that particular file .
You can create many such Common device configurations and assign them to different sets of phones.
Suresh
07-10-2016 09:14 AM
Hi Suchira,
Phone
Suresh
07-11-2016 06:19 AM
Hi Suresh,
Thanks & I have user login device profiles as well.Then CDC can't be applied, do i need to go line level?
Suchira
07-11-2016 09:48 AM
Hi Suchira,
I would prefer line level.
Suresh
