Multicast SRST MOH volume
jrockhill
Is there a way to adjust the defualt sound level of Music on Hold streamed from a multicast SRST router out the PRI interfaces; currently standard communication (voice) is at a reasonable level, however Music On Hold played by a the local flash sounds like a megaphone!
agopala
1. use a wav editor such as CoolEdit to descrease the volume of your original recording and then put it in the flash of the router.
2. If you give me your email address, I can send you some files.
Ashok,
May be its time for you to remove the line from your profile - "Learning VoIP :) One day I will catch up..!".
Pretty impressive profile with 3 CCIE tags.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
thanks for the offer, you can send them to this email address:
j.rockhill@sbcglobal.net
thanks again
