02-16-2004 10:06 AM - edited 03-13-2019 03:51 AM
interface Serial slot/port:23
Can any body can give me a link/URL for me to refer on how can I change the D channel assignment for a T1. Like
interface Serial slot/port:<24 or any channel>
thanks
BAN
02-18-2004 05:15 PM
I don't think there is an easy way, you may look intoTDM crossconnect to try and get it into a different TS, but by definition for a PRI the signaling will be on TS24. What exactly are you trying to accomplish?
02-18-2004 05:30 PM
When using this command in a t1 controller pri-group timeslots 1-24 it will create directly D channel interface Serial1/0/0:23. what im trying to accomplish is to change the 23 to 24 since my telco assign the d channel to 24.
02-18-2004 05:50 PM
OK, is the first timeslot for the telco numbered as 0 or 1? I have never seen a PRI with the D chan in the second to last timeslot unless it is talking to another PBX af the same model through that PRI.
I bet it is in the last timeslot and the numbering is off. If you configure it as pri-group and do a show isdn status, what is the output?
What kind of switch are you connecting to?
If it is not in the last timeslot, inform your provider to make it a standard PRI by putting the D chan in the last TS(you are the customer)
02-18-2004 10:01 PM
i think they start at 1, by they way MCI my provider. And the switch they are using is 5ess. By the way how did cisco number the timeslot? and why is it that 23 is the default d channel.
02-19-2004 11:40 AM
I have run into this "phaseology" problem a few times with various telcos. We tend to look at the slots as 0-23, where the telco engineers tend view them as 1-24. Most of the time, the telco engineers are aware of these perspective differences and will accommodate for it when you turn up and test the PRI's by simply referring to the "last slot" as the d-channel.
