Need to match incoming dial-peer based on incoming port
nms
I've tried overlapping dial-peers with 'answer-addres .' for each voice port but the selected incoming dial-peer will always be the first of the overlapping dial-peers.
Any other ways to do this?
van
This should not be a problem. The fourth step in matching inbound dial-peers is to use the voice port. Check out the following URL:
http://www.cisco.com/en/US/partner/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml#table2
To use the port, I believe you would simply not use any of the other dial-peer commands: called-number, destination-pattern, answer-address....
Good luck.
The voice port is the last item used to match an incoming dial-peer. Any dial-peer with at least one of the other attributes will be selected first, such as your default route dial-peers.
TAC confirm this can be done. So what I have done is use voice port applied translation-rules to prepend prefixes to match corresponding outgoing dial-peers. The outgoing dial-peers use another translations-rule to remove the prefixes before dialing.
So, this allows me to control how calls are routed based on their incoming voice port.
