One Way Audio After Transferring out of a G729 Unity (Over Mgcp)
mdury
We have a Call Manager 3.12c with a Unity 2.46 Running G729 Codec. The problem is this.
Our Default Region Princeton is G711
Our Offsite region is a Vg200 with FXs Ports Running MGCP"Brunswick" is G711
Our Unity is its own Region and it is G729
When Brunswick calls through the Fxs ports to princeton , there is perfect two way audio. IF the call rings no answer to Unity, and then you dial "0" for the operator, or anouther extension, You can hear the Target Extensions Voice, BUT they cannot hear you.
I tried to set up a Voice Class Codec like an H323 Gateway, but I couldn't find anything like that on MGCP. (If that is even the problem)
Here is the Config on the VG200
***IOS 12.2.3
mgcp
mgcp call-agent 11.201.0.2
mgcp dtmf-relay codec all mode out-of-band
call rsvp-sync
ccm-manager redundant-host 11.201.0.1
ccm-manager mgcp
interface FastEthernet0/0
ip address 11.202.0.2 255.255.0.0
no ip mroute-cache
speed auto
half-duplex
ip classless
ip route 0.0.0.0 0.0.0.0 11.202.0.101
no ip http server
voice-port 1/0/0
input gain 3
echo-cancel coverage 32
no comfort-noise
voice-port 1/0/1
input gain 3
no comfort-noise
voice-port 1/1/0
input gain 3
no comfort-noise
voice-port 1/1/1
input gain 3
no comfort-noise
dial-peer voice 101 pots
application mgcpapp
port 1/0/0
dial-peer voice 102 pots
application mgcpapp
port 1/0/1
dial-peer voice 103 pots
application mgcpapp
port 1/1/0
dial-peer voice 104 pots
application mgcpapp
port 1/1/1
ciscomoderator
Community Manager
Community Manager
Often times complex troubleshooting issues are best addressed in an interactive trouble-shooting session with one of our trained technical assistance engineers. While other forum users may be able to help, it’s often difficult to do so for this type of issue.
To utilize the resources at our Technical Assistance Center, please visit http://www.cisco.com/tac and to open a case with one of our TAC engineers, visit http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
