Outbound PRI load balance
m.hedberg
I am trying to figure out how to best load balance outgoing calls over 2 PRI's each on a different router. For example say hypothetically I have 2 gateways, each with a PRI and for the purposes of this question all i need is a 9.@ route pattern. Would i just create 2 9.@ patterns in a different partition and have both of those partitions in the users calling search space? Will that load balanace the calls? and will that allow users to use the second PRI for outbound when the first is all being used?
adignan
Level 8
Level 8
In the route group that the 2 PRI's are in configure each gateway with the same preference. Simple as that.
