Outgoing VOIP dial peer incorret
ani.ak.sharma
Please help with below issue.
Task - To send mobile calls from below VGW to VGW02 (10.26.XXX.XX)
Issue - Outgoing dial peer hiting as 2109 pots. I want to hit 4004 voip dial peer for mobile outbound calls.
VGW Config
IP Phone DN - 888663018901
Called Number - 0921994199
IP Phone--->CUCM--->VGW
trunk group PSTN_02
translation-profile incoming PSTN_INCOMING_CHT
translation-profile outgoing PSTN_OUTGOING_CHT
voice translation-profile CHT_INCOMING
translate called 100
voice translation-profile PSTN_INCOMING_CHT
translate called 3
voice translation-profile PSTN_OUTGOING_CHT
translate calling 4
voice translation-rule 3
rule 1 /^63018/ /88663018/
rule 2 /^3370958$/ /88666028388/
voice translation-rule 4
rule 1 /^88663018/ /3018/
voice translation-rule 100
rule 1 /\(.*\)/ /*5\1/
dial-peer voice 3001 voip
translation-profile incoming CHT_INCOMING
answer-address 88663018[6789]..$
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
fax-relay ecm disable
fax rate 14400
ip qos dscp cs3 signaling
no vad
dial-peer voice 4004 voip
description Mobile Voip Dial-Peer to KHB
preference 1
destination-pattern *509........$
session target ipv4:10.26.XXX.XX
voice-class codec 1
voice-class h323 1
fax rate 14400
no vad
dial-peer voice 2109 pots
trunkgroup PSTN_02
description Local Calls - 10 digit Mobile
preference 3
progress_ind setup enable 3
progress_ind alert enable 8
prefix 09
Scott Pedersen
Took a brief look and made a quick note. Your destination-patterns for both dial-peers match. Typically not a good idea in my experience. I would reconsider what makes a mobile call different from the other calls and perhaps use CUCM to send those calls directly to vgw2 rather than unnecessarily routing through an extra node.
Can you check the reachability of the destination ip of h323 dialpeer.
Based on your preference config, the call will fallback to pots if the
destination of h323 isn't responding.
If the ip is reachable, share the debug cch323 h225
Destination IP is reachable from this VGW.
I have a doubt on the VOIP dial peer 4004, Can a voip DP destination pattern have *5 ?
