Paging solution for CME 4.0
agnel
Any recomendations on Paging solution for CME?
We have a Campus type setup with Offices and manufacturing areas. We would like to page office staff using IP Phones and in manufacturing areas we would like to use Horns. Is there a IP based Horn? Will CME support third party Paging solution? We can use our existing paging system connecting it to the E&M port on CME Router. But we want use IP Paging instead of analog.
Thanks in advance
AD
you can use e&m for paging and moh live feed.
use vic2-2e/m
ps: please remember 2 rate posts.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
thisisshanky
Level 11
Level 11
CME supports 3rd party paging systems (overhead using speakers). I have used Valcom a lot. You will need a FXO port to set this up.
CME also supports paging groups which can be used to page into the speaker phone of IP phones.
Sankar
PS: please remember to rate posts!
Sankar Nair
Thanks!
We have Valcom - analog paging system now. So do we need a FXO or E&M card to support it?
Also we have a external music on hold connection. Can I use E&M for that?
What Cisco modules do I need for FXO and E&M? We have a 3845 ISR Router.
Thanks for your help
AD
use vic2-2e/m
Sankar Nair
