04-04-2005 12:25 AM - edited 03-13-2019 08:36 AM
hi ,
we have a CCM 4.0 and a PBX connected to router. The calls can be made both ways ,but when any PBX phone user makes a call to CCM the number doesnt get dispalyed.
could anyone help me in this??
04-07-2005 01:33 PM
If you are running MGCP between the CallManager and PBX, then you will not get the caller-id displayed. Make use of H.323 gateway.
04-10-2005 03:30 AM
hi,
we are using dial peers for PBX call routing and the same has beed defined for the calls to go from PBX to CCM .
The problem is i can view the called as well as calling number in router but cant there be a way so that i can view the numvber coming from PBX on to CCM 4.0.im only manipulating first one digit.
