Phone not Ringing for Call Pickup Group Calls
zstamm
I am having issues with a phone in a call pickup group. One of the phones is not ringing and can't answer calls for the pickup group. This was working before. There may have been a change made that caused this, but I am uncertain as to what. I am looking for assistance to find what would cause this. What troubleshooting steps should I take?
Notes:
- CUCM 12.5
- Cisco 8851 phone
- I see that the phone goes into a ringing state in the logs on the phone. The calls seem to reach the phone.
- Even though the calls show visually on the phone, you can't pick them up.
- Other phones in the group ring for these calls, and can answer them.
- The volume on the phone ringer is turned up.
- The phone rings and functions normally for direct calls, just not calls in the pickup group.
Ben Petroff
I've seen many problems similar to this. You can try:
Factory Resetting the phone
Re-creating the pick-up group
Restarting the Call Manager Service
If any of these work, it's not a configuration issue that can be fixed, and you're probably hitting a memory-related bug that would require Cisco TAC.
Ben Petroff
Thank you!  I will give that a try.
