Please help me for a CISCO 2911 replacement.
Hi Buds,
I am working in a replacement for some 2911 Cisco routers, wanted to ask you if you know about a Cisco Product or Any product that we can look forward to replace.
These are our specifications.
1. Should support analog FXO or T1 PRI Trunk.
2. Should Support VOICE SIP Protocol.
3. Should support TCL and VXML applications., (VXML is less desirable, but TCL is a must)
4. Dial-peers for SIP.
5. Conference resources are desirable (but not mandatory).
6. It does not need to be the Data Gateway, just the gateways that receives Analog or PRI T1/E1
Basically what we need is the next voice router for the 2911.
Could you please guys advise which Cisco product is the next we can use?
Preferably the most cheap, because these voice routers will be for small offices, like 5-6 people.
Thank you very much in advance.
Leo Laohoo
Without knowing what WAN bandwidth you want, 4331 with Voice license is the bare minimum.
7 Replies 7
Jaime Valencia
If you're a Cisco partner, you should be reaching out to pre-sales for this request
If you're an end customer, you should be reaching out to a Cisco Partner for this.
java
if this helps, please rate
balaji.bandi
here is the link :
https://www.cisco.com/c/en/us/products/collateral/routers/2900-series-integrated-services-routers-isr/eos-eol-notice-c51-737831.html
click and compare now to get new one. also as suggested contact SE for suggestions.
BB
Thanks man,
sure.
Sincerely I have tried to use "we can call you back" option, but no success.
Also have tried the chat and takes a WHILE to happen.
Also (less orthodox) opened a Cisco TAC for question (not about this, but something similar), the TAC engineer was clear... "we do break/fixes, no consultations"
My point here is that getting information is being a little but difficult (form my perspective).
I appreciate your technical answers!
Juan
I am looking at this.
https://www.cisco.com/c/en/us/products/routers/4000-series-integrated-services-routers-isr/models-comparison.html
Do you guys know if any of those support TCL?
I really hope someone with experience on those routers that had the same inquiry as me should be able to tell.
TCL Scripts support on ISR 4K Series.
BB
Leo Laohoo
Hey Legend!  Looks like the 4K router are end of sale now.  Times change quick!!  (I love the jailbird avatar )
