Post static messages to an ip phone
tomide_ccie
i have a request from my client to use xml to post a static message to a set of phones. the message is " Please dial 8 to call 911 !!!. client wants message to continously run or display like a stream on phones. How do i use xml to accomplish this? any help would be appreciated.
Thanks, if it helped please rate the post.
Bye
Alberto
16 Replies 16
agiaccone
You can easily do this POSTing an xml message on the phones.
You should send the message repeatedly every let's say 5 secs, but paying attention to the Priority in the CiscoIPPhoneExecute, using 1 not to annoy users (http://www.cisco.com/univercd/cc/td/doc/product/voice/vpdd/cdd/5_0/5_0_1/ipphsv/ip503ch2.htm#wp1033858).
Put on a webserver this textmessage.xml:
How to Dial 911
then post to the phones this :
http://webserver/textmessage.xml"/>
Alberto
How do you post the CiscoIPPhone execute command to the phone.
msabir
Level 4
Level 4
You can use Idle URL and have it activated at a very low time line -- 5 secs may be.
i was able to at least get a headway using cicoIPPhonetext but CiscoIPPhonetext only posts to the services display window and not the calling window,The doc says to use CiscoIPPhoneStatus for displays to calling window but i can't get that to work. i want the display to show up like IPMA service or something similar. any help would be appreciated.
You can use both CiscoIPPhoneStatus and CiscoIPPhoneStatusFile. The second is the simpler in my opinion.
This case applies on 7970s :
Put a 262x50 message.png image file on a webserver seen by the phones that displays the message you want.
then push to the phones this xml :
"XML=
How to Dial 91100
http://webserver/message.png"
Other phone models have other requirements for the images to diplay.
In case you want to use CiscoIPPhoneStatus, you should use the Gif2Cip.exe tool (in the IP Phone services SDK) to populate the tag. In this case image dimension is 106 x 21.
Alberto
thanks for your help so far......... seems to be getting stuck...see what i have done below:
i copied the script above
define a service in ccm
point the url to the path where the script is
subscribed the phone to the service
in the url i used the ip address, so i wont have to do ns or wins lookup
go to services button and i either get xml parse error or http 404 error.
Heres's my config:
Calling 911.....
http://ccmpub/ccmpd/message.png
IP phone service:
http://10.103.40.223/ccmpd/911B.xml
what am i doing wrong?
The error lies in the fact that you are trying to GET the the xml from the phone, but supports only pushing i.e. POSTing on the phone the instruction.
This means that you should write some code to push that message to the phones.
Here's a small example in c# :
string sXML = "XML=
Calling 911.....
byte[] bb = System.Text.ASCIIEncoding.UTF8.GetBytes("usr" + ":" + "pwd");
MSXML2.XMLHTTPClass xmlhttp = new MSXML2.XMLHTTPClass();
xmlhttp.open("POST", "http://ip_phone_ip/CGI/Execute", true, "", "");
xmlhttp.setRequestHeader("Authorization", "Basic " + Convert.ToBase64String(bb));
xmlhttp.setRequestHeader("Connection", "close");
xmlhttp.setRequestHeader("Content-type", "application/x-www-form-urlencoded");
xmlhttp.send(sXML);
where usr and pwd are the credential of a user who controls the device.
Remember that there's no way for the user to remove this message if pushed this way, the only way is to send another xml to the phone that re-init the screen :
Alberto
Thanks for your help so far, i decided to use idle url but the banner stay on forever until a user presses the exit softkey, what i want is to have the page refresh itself at a specific interval....i have tried to use the refresh keyword but it does not work, see my code below:
-1
-1
125
40
Refresh:3
XXX
For Emergency dial 8911
HelpDsk
Dial:XXXXXXXXXXX
SOC
Dial:XXXXXXXXXXX
Exit
SoftKey:Exit
what i meant by refresh is that i want the page to display for say 5 mins then go away without user intervention and come back again at the specified idle interval.
If you are open to a commercial but very attractively priced product, check out PhoneTop Messenger. If nothing more, it might help you get some ideas.
In order to make the page refresh itself you should add a Refresh header in the page you use as Idle url.
Try to add this on top of your Idle page :
<%@ Language=JavaScript %>
Response.AddHeader( "Refresh",
"300; url=http://myip/blank.xml");
Response.ContentType = "text/xml";
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/all_models/xsi/6_0/english/programming/guide/xsi60htp.html#wp1034199
where http://myip/blank.xml is a blank page.
this way when the phone's idle, it gets to your message with an header that says "after 300 seconds refresh to blank.xml" i.e. delete the message from the screen.
When the phone comes back idle, everihing starts again.
Alberto
did that but am getting an XML ERROR [4] parse error, see my code below:
"30; url=http://ccmp/ccmpd/blank.xml");
-1
-1
125
40
0000000000000000000
Refresh:3
xxx
HelpDsk
Dial:xxxxxxxxxxx
SOC
Dial:xxxxxxxxxxx
Exit
SoftKey:Exit
be sure to have renamed your Idle url file in .asp, for example idle.asp.
This configuration worked for me :
Idle url :
http://10.10.10.10/idelUrl.asp
Idle Timer : 30 secs
in the idleUrl.asp file the refresh url occurs after 30 secs pointing at blank.asp where I put this instruction :
that means "Press the Services key" i.e. close the window.
Attached you'll find the files that worked for me.
Alberto
Alberto, you rock man. Works like a charm. just need to play with timeouts and what not.
