Power Specs
cfrankl54
I'm currently building a redundant network with the following switches and router and need the power specs in advance for my electrician. Any help would be greatly appreciated. Either amps or watts is acceptable.
6509 switch -
3550 switch -
2912 switch -
3560 switch -
7206 router -
thanks
paolo bevilacqua
for the 6509 and 7200 it depends on the installed number and type of powers supply, for the other ones the data in in the data sheet that you can find under "products" on CCO.
