prefix 0 to incoming calling number ?
agr
Hi all,
I have one question, we use a mgcp gateway with ccm3.2 is it possible to prepend a "0" to the incoming calling number on the callmanager and if how ;-)
We made it with a translation pattern but it works only if there´s really a translation ...
any help would be great
thanks in advance
Andi Gruber
Translation patterns (TP) is the way to go. Presumably calls from the MGCP GW have the full DID number as the called number. Have the translation pattern match on the DID indial range, and then mask of the last N digits as the extension. At the same time specific a '0' prefix in the calling party transformaion.
paul.harrison
Level 4
Level 4
This is based on prefixing a 9 (for UK) but is easily modified to prefix with whatever digit you like.
I've done this in the following way.
partition - incoming_p
calling search space - incoming_SS, contains incoming_p
partition - internal_p
calling search space - DDI_SS, contains internal_p
gateway assigned to the incoming_SS
Translation pattern ! assigned to the partition incoming_p, modify incoming cli to 9xxxxxxxxxxx, search space of DDI_SS.
This way all incoming calls are sent through the translation pattern and a 9 is added infront of the 11 incoming digits (if BT are the provider change to 90xxxxxxxxxx) and then all incoming CLI has a 9 in front. The search space then passes the call to the internal_p which contains my extensions
This is based on all incoming CLI being the same length, if you have varying lengths then this will have strange results.
Paul
Is it possible to change the incoming caller ID depending on the calling party number not called party number?
I have a different requirement than prefixing all incoming calls with 9. If a call comes in from 91951[2,3,5]XXXXX I need to strip the 91951 and only show the last 5 digit of the calling party number. For all other calls I need to prefix the 10 digit Caller ID with a 9.
I could do this on my H323 PRI gateway by using translation rules and appliying them to different dial-peers. Recently I've implemented PRI backhauling on the gateway and the translation rules no longer work. Can this be done with the callmanager running 3.1(3aspD)?
Baha
Is there a way to make a translation depending on the numbering type ? For example if I receive an international call I want to prefix the number with 2 zeroes and if it's a local only 1 zero.
Bram
