12-29-2003 07:57 PM - edited 03-13-2019 03:09 AM
I just completed an upgrade for a customer going from 3.1(3) to 3.3(3). Everything went very smoothly. I used the 3.3(3) disks that are shipping from Cisco now. When I went to apply SR3 it failed every time. It would hang for almost an hour before I cancelled it out and there were no processes running. This is the first time I have installed sr3. Is anyone else having this problem or know why it is happening?
12-30-2003 05:18 AM
Its not hanging...its just taking forever to install. I had the same problem with sr2. It took me about 1.5 hours for it to install on a dell poweredge 2400 with dual 733's and 1gb ram. I also noticed that no processes show, but there is a hidden console screen that appears to be running in the background which shows a ton of 'sleep' commands....so basically it seems like it is running a command then waiting a while, then running another command, then waiting, etc....
I would just let it run...it WILL take a while though. just an FYI.
12-30-2003 08:29 AM
Jeremy,
We installed the Sr3 patch a couple of weeks ago and eveything seemed fine. Installed on 3x7835 and 1x7825-800 in the same cluster. The 7825 took the longest at about 20 minutes. The 7835's took only 10 -15 minutes.
D
