04-12-2005 07:00 AM - edited 03-13-2019 08:42 AM
I have a 2821 at the main site with the v3pn, and a 2801 at a remote site with the v3pn. They are connected with an internet VPN connection. I am also running CallManager 4.0 at the main site. I am unable to get the remote 2801 to register with CallManager, and I think it has to do with the vpn connection and possibly because the remote router is probably trying to register with the external internet IP? If anyone has any suggestions I would really appreciate it.
Solved! Go to Solution.
04-12-2005 07:30 PM
you may want to check your gw type (h323 or mgcp) and the associated bind source interface commands.
there is an mgcp bind source (for control and/or media) and also an h323 bind source address.
04-12-2005 07:30 PM
04-12-2005 08:34 PM
Like Charles suggested, it is the problem with the source address used by MGCP to register with your Callmanager. Check the MGCP bind source command under global config mode.
