Problem with cisco dx650 touch screen
sam2_sammy
Dear all,
I have problem with cisco dx560, then touch screen is not responding. Can anyone advise.
thanks
Samuel
Aman Soi
Hi Samuel,
check for the bug
DX-650 has touch issue near the notification area
CSCuw99960
Description
Symptom:
DX650 does not respond to touch in some cases. Notification pop-up is not active for the touch in some cases.
Conditions:
Issue has been seen with white DX650, when touching notification area of the device.
Workaround:
None
Known Affected Releases:
(1)
10.2(5)
Aman,
Thanks, how ever can you kindly guide how to go about fixing this problem
Hi Sam,
suggest upgrading to latest 10.2(5.212)SR4 even the workaround has not been mentioned in bug  else open TAC case .
regds,
aman
