Problem with the clock
hbejinha
I have a problem with the clock source.
in this situation is the router giving the clock to the
Alcatel.
im receiving this error from the router
Feb 22 10:56:08.626 GMT: BRI1/0: !!!CHECK CLOCK SOURCE!!! and the interface is disabled due to Lost framing count of 41 in the past
and the router shutdown the bri .
this is the configuration from the bri
interface BRI1/0
description Ligacao ISDN ao PBX
no ip address
no ip mroute-cache
isdn switch-type basic-net3
isdn overlap-receiving
isdn protocol-emulate network
isdn layer1-emulate network
isdn incoming-voice voice
no isdn T309-enable
isdn send-alerting
isdn sending-complete
no isdn outgoing display-ie
isdn static-tei 0
isdn skipsend-idverify
line-power
Anyone with a tip?
Hugo bejinha
Aaron Harrison
Hi Hugo
Have a look at this document:
http://www.cisco.com/warp/public/788/signalling/bri_voice_port_cfg.pdf
On the bottom of page four it says:
Cisco IOS currently only supports layer 2/3 network side operation with QSIG, NET3 and NI ISDN
switch types.
Since you are using NET3, it looks like the Cisco card won't provide clocking (Layer 1) - can you have your Alcatel provide this? Or use a different ISDN switch type setting?
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Hi Aaron,
First thx for the fast help.
I looked the document but in the document isnt talking anything about layer1 :(.
the card from the alcatel must be in slave mode because is the same card that is connected to the public PBX.
Hugo Béjinha
mulicny
I have the same problem on c3725, c3640, c2600xm models. Older versions of IOS worked fine on model c2600xm (12-2-16 or 17 IPPlusIPsecDES). We tried to change the gender (in a lab) and the clock timing looked stable.
