problems getting pictures of employees on 7960/40 phones
dlittlewood
I am trying to write a simple program for the IP phones that will display employee details including pictures. The problem is that when I convert the pictures to cip and then view them from the phone I cannot make them out at all. I have seen a demo from Cisco where they have a picture of John Chambers which looks fine, does somebody know how to do it?
msolak
Level 4
Level 4
The Pictures musst be smaller as 133x64 pixels. Make it smaller before converting to cip.
Mehmet
Hi, I did this. I used PSP to resize the image to 133x64 then i also decreased the amount of colours used to the 4 colours the phones support. It looked bad. Even if I left the image the original size and then decreased the colours it looked bad. I cant think of anyway round it but to draw the images by hand from scratch. Have you been succesful with this at all?
can you send me a copy of your example ?
I can test it in our lab.
Mehmet.Solak@deteline.de
mehmet
