09-24-2004 03:59 AM - edited 03-13-2019 06:27 AM
After upgrading CCM 4.0(1) to 4.0(2)a
a 7970 phone has stopped working.
7970 firmware: cmterm-7970-sccp-6-0-1.
As it wasn´t booting at all I´ve performed a
factory reset. After the leds going yellow and red
for the reset they now keep going green and
doesn´t show startup window even 30 minutes later.
Any suggestions would be highly appreciated.
09-30-2004 08:45 AM
This could be due to the issue with the switch to which the phones are connected to. Check if there are any issues with the switch.
10-05-2004 08:21 AM
The switch (Catalyst 2950) doesn´t seem to be the problem as I have now a 7960 connected to the same port I had the 7970 connected to working OK.
I think the firmware may have gone corrupt during
the factory reset or something like that. I´ve read
about a bug for 7935s in similar circumstances
making the 7935 unusable.
10-06-2004 10:22 AM
I had a 7970 phone quit working in the same manner that you have described. Only, mine stopped working when I was doing a firmware upgrade to the phone. Regardless, the phone would not complete the boot process and had to be RMA'd.
10-11-2004 05:56 AM
I also asked for RMA for my 7970,
as it won´t complete the boot process either.
Thanks for your comments.
10-12-2004 09:43 AM
Also, There is a new firmware release than the version you previously stated you were using.
Available on CCO download.
