10-16-2002 06:25 AM - edited 03-12-2019 09:11 PM
I configured message notification, and it correctly calls the user when a message is left and says if you would like to hear your messages, enter your id now. When you enter the ID, the call disconnects.
10-16-2002 07:06 AM
Which version of Unity? Switch integration?
any errors in the application event log when this happens?
when you say disconnect, it just hangs up on you right after you enter your ID without any prompt playing? No opportunity to enter your password or the like?
10-16-2002 08:04 AM
I found another post that suggested the problem probably was that the router was not matching the digits I was sending in when I tried to enter the ID. I created a voip dial peer on the router with incoming called-number .... and sure enough, that was the problem.
