08-15-2005 07:02 AM - last edited on 03-25-2019 06:48 PM by ciscomoderator
here we are setting up a pilot installation of Cisco Unity. I also installed the T.37 Store and forward fax functionality with a 2611XM gateway-router.
Everythink worked fine for some days. But since today I cannot process outgoing faxes and I get the following failure in my IPFaxSvc logfile:
"2005-08-15","17:01:01","Processing outbox, message count= 1"
"2005-08-15","17:01:01","_RecordsetPtr::Open(Select * from tblIpFaxData where MessageEntryID = '0000000015DE036E14ACE34398B00F08E0261A0507002EF3B57CF0C17A4796FDD3119D3BC2C0000000028FCF00002EF3B57CF0C17A4796FDD3119D3BC2C00000000292060000') returned [0] rows - Code: 0x80004005. Method: CIpFaxAdoHelper::GetRecordSet. [IpFaxAdoHelper.cpp::403]"
"2005-08-15","17:01:01","Caught exception - Code: 0x80004005. Method: CIpFaxAdoHelper::Execute. [IpFaxAdoHelper.cpp::357]"
"2005-08-15","17:01:01","CIpFaxAdoHelper::Execute() failed - Code: 0x80004005. Method: CIpFaxOutboundMessageData::SaveMessageRecord. [IpFaxOutboundMessage.cpp::150]"
"2005-08-15","17:01:01","SaveMessageRecord() failed - Code: 0x80004005. Method: CIpFaxOutboundMessageData::LoadMessageRecord. [IpFaxOutboundMessage.cpp::203]"
"2005-08-15","17:01:01","CIpFaxOutboundMessageData::SetMessageID() failed - Code: 0x80004005. Method: CIpFaxCdoHelper::ProcessCurrentMessage. [IpFaxMessageHelper.cpp::1224]"
"2005-08-15","17:01:01","ProcessCurrentMessage() failed - Code: 0x80004005. Method: CIpFaxCdoHelper::ProcessFaxOutbox. [IpFaxMessageHelper.cpp::682]"
"2005-08-15","17:01:01","CIpFaxCdoHelper::ProcessFaxOutbox() failed - Code: 0x80004005. Method: CIpFaxInboundRouter::ProcessFaxOutbox. [IpFaxInboundRouter.cpp::248]"
"2005-08-15","17:01:01","ProcessFaxOutbox() failed - Code: 0x80004005. Method: CIpFaxInboundRouter::MonThreadProc. [IpFaxInboundRouter.cpp::201]
I searched for the failure for hours, but I did not get any solutions. Does anybody know, how to solve this failure?
Thanks in advance and greetings from Ludwigshafen/Germany
Florian Zahn
08-19-2005 06:15 AM
Check you config with below
Try using Unity IP Fax Configuration Wizard
http://www.ciscounitytools.com/App_IPFaxConfigurationWizard.htm
