QoS for Thrid Party VoIP Gateway
jeff.yau
We are using Planet voip gateways for voice communication. I want to understand whether I can set up QoS on my routers to enhance the voice quality or not. It the routers support, how to setup?
We are using 3640 IOS C3640-JS-M, Version 12.2(7)in head office and 1701 with IOS C1700-Y-M, Version 12.3(1a) in remote office.
Any comments are appreciated.
munatara
You can use LLQ for this setup. You can create a class-map to match the rtp packets. Create a policy-map to define bandwidth for the class-map; finally apply the policy-map in the interface.
Hope this link helps.
http://www.cisco.com/en/US/tech/tk652/tk698/technologies_configuration_example09186a0080094af9.shtml
munatara
