Question when configuring translation in VoIP Gateway
sethplate10
I had the carrier send me the last 2 digits of our DID numbers.Although we are not using a Gatekeeper, a guy before me configuredthe VoIP Port with a tech-prefix 68.
At present I am doing translation in the CallManager, translating 68XX to 779XX.
1) I would like to do the translation in the VoIP
Gateway, is this possible?
2) Can you suggest any sample translation
configuration ?
3) If I do the translation in the VoIP Gateway
router, do I need to do any configuration in the
Router so that the DID number for each IP Phone
will be displayed instead of the representative
number ?
Please advise.
Note :
VoIP Gateway : Cisco 1700
IOS Version : Version 12.3(4)T8
CallManager Version : 3.3.3
2 Accepted Solutions
nmilojevic
Hi!
Well, you can configure prefix 779 instead of 68.
Or, you can try this:
-turn off tech prefix 68
-enable voice translation profile on incoming (POTS) dial-peer:
translation-profile incoming example1
-create profile and rule:
conf t
voice translation-profile example1
translate called 100
voice translation-rule 100
rule 1 /^/ /779/
This should do the trick. If you want, you can also do it on the outgoing (VoIP) peer. As for your question number 3, I really don't know, what will come up on the IP phone.
Nikola
Right, I would un-configure the tech-prefix since it is not a good place to use it outside of RAS.
Mike
(BUT ALWAYS TRY THIS OFFLINE FIRST SO YOU DON"T TAKE DOWN YOUR PRODUCTION NETWORK) :)
Mike
8 Replies 8
nmilojevic
Hi!
conf t
rule 1 /^/ /779/
Nikola
Thanks Nikola. I really appreciate it.
Bsically the wild cards you used meant to put 779 at the beginning of the received digits from the carrier right ?
rule 1 /^/ /779/
Thanks.
Correct.
Have a look at this documents, once you get a grip, it is a powerfull tool.
There are two sets of translation rules - old and new.
Old rules are simple and don't allow wildcards;
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a0080080aec.html#wp1244453
New rules (profiles) are more powerfull;
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml
Nikola
mcotrone
Level 3
Level 3
It depends on what kind of gateway signaling is currently being used between your 1700 and the CCM. Are you using MGCP or H323? If you are using H.323 then the MOST easiest way to manipulate your digits is by use of either the num-exp command or translation patterns. There is no need to use a tech prefix when you aren't using a gatekeeper by the way. See example:
num-exp 68.. 779,,
The only thing I hate about the Num-exp command is that is it bi-directional. Some people may only wnat to xlate in one direction. I prefer the translation patterns since you have control on a per call leg scenario.
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729br8
translation-rule 1
Rule 1 68 779
dial-peer voice 199 voip
desintation-pattern 68..
session target ipv4:10.1.1.1 (ex IP)
translate-outgoing called 1
preference 0 <-- Use if you are going to have more than one DP pointing to other CCM's
voice-class codec 1 <-- If you don't specify then G729 is used
Now anything that hits Dialpeer 199 starting with 68 will then be translated to 799.
You can test this config with the global "test translation-rule 1 682323" and you will see "7792323"
Just make sure that the Call Manager is looking for the digits starting with 779 now instead of 68.
Does this help?
Mike
Mike,
I am affraid the guy before him configured tech-prefix ON the outgoing voip dial-peer, so with the "destination-pattern 68.." he won't catch calls on this same peer.
Nikola
Mike
Mike
Thank you for your help, I learned a lot!
Best Regards
Anytime.
