Hi Istvan,
Cisco routers can work in both Enbloc and Overlap modes as explained in the following doc
http://www.cisco.com/c/en/us/support/docs/dial-access/dial-on-demand-routing-ddr/23382-isdn-overlap-prob.html
You can either check with your Telco if they can send the DNIS as per your requirement, else you always have the option to configure your gateway accordingly.
Manish
