04-29-2003 05:31 AM - edited 03-12-2019 11:39 PM
Would like to be able to simply dial 1-xxx-xxx-xxxx. how would I do this?
04-29-2003 05:48 AM
you can do a couple of things here. The best way is to make a route list and include the route group you are using in it. on the route group properties page put a 9 in the "Prefix Digits (Outgoing Calls)". I use this for a number of things, you can use a 91 and they only have to dial 10 digits it is up to you.
Geoff
04-29-2003 08:32 AM
Here are some links to dialplan for CM:
http://www.cisco.com/warp/public/788/AVVID/us_dialplan.html
http://www.cisco.com/warp/public/788/AVVID/dp_isdn_gateway.html
http://www.cisco.com/warp/public/788/AVVID/call_routing.html
Chinh
