Replacement for Motolora Vanguard 6455
robin
can someone suggest what items to replace the above with the details:
Vanguard 6455 Base Unit, Worldwide Version.
Vanguard 6455 Multiservice Applications Ware License.
6.0 Applications Ware Software Release Indicator
4 Meg Flash Upgrade
Frame Data Compression (15 Channel DSP)
Power Cord, Schuko CEE 7, Europe
V.35 DTE DIM - Port 1
V.36 DCE DIM - Port 2
E1 VOIP Convergence Module 120 Ohm (includes E1 option card and voice server modules - 2 x 16 ch DSP)
Chester Rieman
Kind of hard to say from this. Can you please provide a description of what you are doing here and what you need to connect to? If you have a cisco account team or SE, they would be glad to go over this with you as well.
