Ring all Phones
Gunnar Reiser
Level 4
Level 4
Hi all,
is there a way (using CCM3.3 and 7940 Phones) to let all Phones ring at the same time not using a shared line? Something like an alarm notification.
I'm also concerned about the power drain using inline power and Catalyst 3550 switches. Are limitations known here?
Thanks and Regards
Gunnar
eric.fairfield
Level 4
Level 4
Look at Informacast on the URL below. It will send a multicast paging alert to your 7940's. Version 2.0 can even integrate with an overhead paging system. Many organizations use this app for emergency notificiation. That is why it was originally developed.
http://phone-xml.berbee.com/
5 Replies 5
eric.fairfield
Level 4
Level 4
calmichael
Take a look at the attached script which can be used
with a H.323 gateway to provide multiring capability.
It should do what you want given that you have a H323
gateway available where the pilot number would be
delivered to.
Hello
I'm interested in your script. I tested that in 1760 but it doesn't work.
Can you please help me?
Were you able to get this working with a 1760 and 7940 phones?
Thanks in advance
i also used your script. It works fine for the 7905
but the 7960/7940 didn't ring.
Thanks for your help.
