03-09-2006 01:17 PM - edited 03-15-2019 04:10 AM
I'm stumped on how to accomplish the following.
1) I need if someone calls 1234 for CallManager to route this to the gateway.
2) I need if someone dials 1XXXX (ex. 18693) for CallManager to route this over the same gateway.
My problem is that when I create these routes, the first one works until I create the second one and then it just hangs waiting for the 5th digit (example I dial 1234 after creating the second route plan and it just hangs there waiting for the 5th digit). Any help on this is greatly appreciated.
Josh
03-09-2006 05:01 PM
Josh,
set urgent priority (check) on 1234.
Sankar
PS: please remember to rate posts!
03-10-2006 04:17 AM
Thank you for your assistance. This fixed my problem.
Josh
03-09-2006 05:44 PM
Josh,
1st create a translation of 1234 such that everytime 1234 is dialed it becomes 1234X , basically appending a 5th digit to it. That makes it = 1XXXX and that should take of it. Perhaps there is a simpler way - I haven't built route plans in a while.
Omoruyi
