RTP JMF help!
Davide Fiumi
I'd like developing an application that, from one phone, sends an audio prompt to another phone.
I think to use JMF API. So I download AVTransmit2 and AVReceive2 but I don't know how to use them.
Can you help me?
For example:
IPSenderPhone(172.20.0.1)
IPReceiverPhone(172.20.0.2)
I must install JMF, compile java file and then?
Thank you
stephan.steiner
as far as I recall if you launch avtransmit2 without parameters (it's a commandline program, so launch it via "java avtransmit2" it should tell you how you can use it. There's a source, an IP address and a port as parameters I think). To receive, I suggest using JMFStudio that you'll get by installing the JMF framework.. it'll make things a bit easier for you.
