Script Error When Web Browsing to Call Manager Administration
ischarcm
I am using windows XP with IE 6.0.2800 128 bit encryption. When I browse to the call manager only half the pages (headings) are coming up with a script error indicated at the bottom of the screen by a yellow triange.
Line 264, Character 3. Object doesn't support property or method. I have downloaded java virtual machine, but this did not help. Moved all security settings to their lowest, this did not help either. Any ideas?
PvanBreda
go to http://www.java.com/en/download/windows_automatic.jsp
and install the sun java. Try again afterwards.
5 Replies 5
PvanBreda
that worked! Thanks!
I unload the application but does not allow me to have more than one page being administered two to call manager. AS I SOLVE THAT?
hmmm - are you ensuring you are logging onto the CCM pages using the hostname as opposed to IP address?
http://>/ccmadmin
http://CCMSERVER/ccmadmin
cheers
yes, i do it
but it not chance anything, so apparently that the problem was that i installs on my computer Windows 2000 with service pack 4
