Sending Fax problem
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
08-29-2012 03:07 AM - edited 03-15-2019 05:22 AM
We have a netwrork RightFax and we are able to send Faxes to local numbers but not to an international number.
You can find below the configuration on the voice gateway and the output of " sh call history voice brief "
Kindly advice what does " Interworking 127 " mean and how can we solve this issue.
Could this problem be due to the E1 ?
Thanks in advance,
Mirna
2524 : 684972 08:53:41.660 UTC Wed Aug 29 2012.684902 +6760 +41050 pid:5 Answer
dur 00:00:34 tx:1702/271286 rx:1333/319920 7F (interworking (127))
IP 172.16.164.180:56504 SRTP: off rtt:0ms pl:33240/100ms lost:1/1/0 delay:65/65/75ms g711ulaw TextRelay: off
media inactive detected:n media contrl rcvd:n/a timestamp:n/a
long duration call detected:n long dur callduration :n/a timestamp:n/a
2524 : 684973 08:53:41.978 UTC Wed Aug 29 2012.684904 +6440 +41190 pid:202 Originate 0096265652186
dur 00:00:34 tx:1108/274784 rx:1702/271286 7F (interworking (127))
Telephony 0/0/0:0 (684973) [0/0/0.26] tx:34260/33920/0ms g711ulaw noise:-84dBm acom:51dBm
voice translation-rule 30
rule 1 /^66/ /9/
voice translation-profile test-fax
translate called 30
dial-peer voice 5 voip
description outbound from fax
translation-profile incoming test-fax
destination-pattern 6666
session target ipv4:172.16.37.121
session transport udp
incoming called-number 66.T
voice-class codec 66
dtmf-relay h245-alphanumeric
fax rate 14400
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
dial-peer voice 202 pots
corlist outgoing Partition-Block
description ---- International via E1 Ogero
translation-profile outgoing remove9
destination-pattern 900T
port 0/0/0:0
forward-digits all
- Labels:
Other Collaboration Topics
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-03-2012 09:59 AM
Hi Mirna
Cause No.127: interworking, unspecified. This cause indicates there has been interworking with a network that does not provide causes for actions it takes; thus, the precise cause for a message being sent cannot be ascertained.
Please post your debug isdn q931 command output, with a failed call also post a with call that worked (Local)
Please rate this post
Bruno Rangel
Please remember to rate helpful responses using the star bellow and identify helpful or correct answers
