02-09-2007 08:13 AM - edited 03-13-2019 03:55 PM
Hi..
i don't know what's wrong with my own CallerInfo.java - it's registering onto the CallManager and seems to work, but i never get any event change when receiving a call for example ... i am not THAT new to Java, so i could compile everything, JTAPI and SDK are working ...
*** SNIP ***
import com.cisco.ipphone.sdk.CallerInfo.CallerInfoServer;
public class CallerInfo {
private String callManager = "xxx.xxx.xxx.xxx";
private String jtapiUserId = "user";
private String jtapiPassword = "password";
private String phoneName = "myphonename";
private String[] numbers;
public CallerInfo() {
CallerInfoServer callerInfoServer = CallerInfoServer.getCallerInfoServer(callManager, jtapiUserId, jtapiPassword);
numbers = callerInfoServer.getActiveCallPartyNumbers(phoneName);
if (numbers != null) {
for (int i = 0; i < numbers.length; i++) {
System.out.println(numbers[i]);
public static void main(String[] args) {
new CallerInfo();
*** SNAP ***
My Consoles out:
Creating the CallerInfoServer ...
Initializing Jtapi
Opening JTAPI provider connection to xxx.xxx.xxx.xxx ...
Provider successfully opened.
CallerInfoServer successfully created and running.
02-12-2007 12:17 AM
No Idea? Anyone?
02-13-2007 12:22 AM
I'd try importing cisco's callerinfo classes into your own project then debug.
That way you'll see if you get any CallEv's or not and we can take it from there.
