softphone
davidcruise
i have Cisco Call Manager V 4.1 &i want to use softphone with it .
so what is the versions of softphone thatis supported by CCM 4.1
you would be better off using Cisco Ip Communicator which has replaced Softphone
Rob Huffman
Hi David,
Richard is correct in steering you towards IP Communicator. Check out the link below for the CCM Compatibility Matrix. This will help you with versions that are tested with your CCM 4.1.? I believe the latest version of IP Communicator is 2.0.1.
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/ccmcomp.htm
I have also attached a link to the IP Communicator Data Sheets.
http://www.cisco.com/en/US/products/sw/voicesw/ps5475/products_data_sheet09186a00801f8e48.html
Hope this helps!
Rob
Please remember to rate helpful posts....
kevin-saunders
no softphone (original H.323) supported for CCM 4.1x
go for IP Communicator version 1.1(3) or later. Recommend v2.0(1)
