11-05-2008 02:22 PM - last edited on 03-25-2019 06:57 PM by ciscomoderator
I want to add the speed dialing on the phone. I tried to add it on CCM server and CCM user web but it's not working. Is there any setting I should configure before adding the speed dialing?
Thanks. Leo
Solved! Go to Solution.
11-05-2008 03:34 PM
none, exactly what you did?
created a new button template with SP, configured the phone to use it and then configured SP, reset the phone???
please always include CUCM version
java
if this helps, please rate
11-05-2008 03:34 PM
java
