SRST not Test OK
spverizonrd
My scenario:
We have a CCM cluster on city A and a router 2811 on city B, the call processing is OK, but the SRST Test not.
When We apply ( disconnect ) fail over to simulate SRST mode:
1.- Call over T1 go 120 IPM
2.- The POE switch send traffic over wan
3.- The call Manager not certify the secure SRST, retur error
Thank,
Juan
5 Replies 5
Chris Deren
Please post your SRST router config.
Chris
Check attach
thisisshanky
Level 11
Level 11
Juan,
Your Secure SRST config is not complete. I would suggest you to get regular SRST working properly prior to configuring Secure SRST. (One step at a time).
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Sir,
Can you refresh me the step?
So I need to run a check list to verify
Thank
Juan
Here is a non-secure SRST sample config. You may not need all of it. This is just something thats running in lab..
call-manager-fallback
secondary-dialtone 9
max-conferences 1 gain -6
transfer-system full-consult
timeouts interdigit 7
ip source-address 10.5.201.1 port 2000
max-ephones 3
max-dn 6 dual-line
dialplan-pattern 1 6175222... extension-length 4
transfer-pattern .T
keepalive 20
voicemail 912122221600
call-forward pattern .T
call-forward busy 912122221600
call-forward noan 912122221600 timeout 12
moh SampleAudioSource.ulaw.wav
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
port 0/0/1:23
dial-peer voice 2 pots
destination-pattern 911
port 0/0/1:23
forward-digits all
dial-peer voice 3 pots
destination-pattern 9[2-9]......
port 0/0/1:23
forward-digits 7
dial-peer voice 4 pots
destination-pattern 91[2-9]..[2-9]......
port 0/0/1:23
forward-digits 11
dial-peer voice 5 pots
destination-pattern 9011T
port 0/0/1:23
prefix 011
To add Secure SRST into this picture, you need a CA server (can configure your SRST router to be the SA) For this you need Advanced IP services or better feature set to support both voice and encryption. Here is a good link to start with for Secure SRST.
http://www.cisco.com/univercd/cc/td/doc/product/voice/srst/srst33/srst33ad/index.htm
In the link, check the section Setting up Secure SRST
sankar
PS: please remember to rate posts!
Sankar Nair
