Stop incoming calls based on calling number
imrebalazs
hi,
I should stop /drop/ certain malicious incoming calls from PSTN network based on calling number. There is a PRI used on the router to terminate 5 ISDN30 channels. Does anyone has an idea how to do that?
TIA,
Balazs
Zin.Karzazi
Level 5
Level 5
H323 or MGCP?
From what i know this is only possible with an H323 Gateway.
http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K15182736
Karzazi
rate if helpful.
hi,
MGCP unfortunatly
Is there maybe a way to do that in case of MGCP?
Maybe with IVR?
Balazs
If you are using IPCC you can do a digit analyze with a Script and release the Call if the call cames from a specific number. But the best way is to tell your Phone Company to block that number for you.
Karzazi
