06-01-2005 09:04 AM - edited 03-13-2019 09:17 AM
I have setup T.37 fax on a cisco 2651xm with a AIM-30 most faxes seems to come through fine but high graphic ones or pages with allot of dark detail seem to come through all screwed up or even missing the bottom half of the page.
The strage thing is this might happen to page one but page two which has just text on it will come through ok so the connection is not dropping after the bad page.
Can anyone please help, as i have given up with ATA boxes and we need a working fax solution without the expense of VG200...
Andy
06-01-2005 11:46 AM
put "image resolution super-fine" in your mmoip dial-peer and try again. This works for me pretty well on a 5350.
If it does not work, post your config.
06-01-2005 11:47 PM
That did not work, here is my config.. Thanks Andy
hostname gateway
boot-start-marker
boot system flash flash:c2600-ipvoice-mz.123-11.T5.bin
boot-end-marker
logging buffered 20000 informational
memory-size iomem 10
clock timezone GMT 0
clock summer-time BST recurring last Sat Mar 23:59 last Sat Oct 23:59
no network-clock-participate wic 0
voice-card 0
dspfarm
no local-bypass
ip subnet-zero
ip cef
no ip domain lookup
ip domain name asp.node4.co.uk
ip host n4-tftp 10.200.1.20
ip host N4-RAD-01 10.2.0.11
ip name-server 10.0.1.1
no ftp-server write-enable
isdn switch-type primary-net5
voice call convert-discpi-to-prog
voice call carrier capacity active
voice rtp send-recv
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class h323 1
h225 timeout tcp establish 1
ccm-manager music-on-hold
fax receive called-subscriber 01158514999
fax interface-type fax-mail
mta send server 10.0.1.17 port 25
mta send subject Fax from Node4 VGW-02
mta send with-subject both
mta send postmaster fax@node4.co.uk
mta send mail-from hostname node4.co.uk
mta send mail-from username $s$
mta send return-receipt-to hostname node4.co.uk
mta send return-receipt-to username $s$
mta receive generate mdn
controller E1 0/0
pri-group timeslots 1-31
description *** 31-Channels - ***
translation-rule 1
Rule 0 . 90
translation-rule 3
Rule 0 . 90
gw-accounting aaa
interface FastEthernet0/0
description *** 100Mbs Link to GE6/12 VLAN51 ***
ip address 10.0.2.21 255.255.255.0
ip access-group 100 in
speed 100
full-duplex
h323-gateway voip bind srcaddr 10.0.2.21
interface Serial0/0:15
no ip address
isdn incoming-voice modem
no cdp enable
interface FastEthernet0/1
description *** not in use ****
no ip address
shutdown
duplex auto
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 10.0.2.254
ip http server
control-plane
call application voice onramp flash:app_faxmail_onramp.2.0.1.3.tcl
voice-port 0/0:15
cptone GB
no mgcp timer receive-rtcp
dial-peer voice 10 pots
destination-pattern 9T
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
fax rate disable
direct-inward-dial
port 0/0:15
dial-peer voice 2 voip
preference 1
destination-pattern [1-8].........
progress_ind setup enable 3
translate-outgoing calling 1
translate-outgoing called 3
modem passthrough nse codec g711ulaw
voice-class codec 1
voice-class h323 1
session target ipv4:10.0.2.2
dtmf-relay h245-alphanumeric
expect-factor 5
no vad
dial-peer voice 3 voip
preference 2
voice-class codec 1
voice-class h323 1
session target ipv4:10.0.2.1
expect-factor 5
no vad
dial-peer voice 1 mmoip
application fax_on_vfc_onramp_app out-bound
destination-pattern 1158514999
information-type fax
session target mailto:$d$@node4.co.uk
image resolution fine
dial-peer voice 1158514999 pots
application onramp
incoming called-number 1158514999
direct-inward-dial
end
06-02-2005 12:23 AM
Maybe the issue is not in the T.37 fax-to-mail (TIFF) conversion, but with the faxes at all. Try to send a fax from a fax machine to a fax machine via VoIP. If the quality is bad, try this command under the voip dial-peer:
fax-relay ECM disable
