Transparent CCS configuration at C7206 VXR and C3661
ouslu
I am going to install a new network, there will be c7206 VXR ( with pa-vxc-2te1 ) on the h/q and c3661 ( with nm-hdv-1e1-30e) at the branch offices ( there will be 5 branch offices). All branch offices will connect to the h/q with E1 leased lines.I will use hdlc. There are Ericson MD110 PBX's at the branches and h/q. Those PBX's will be connected to the routers using TCCS. There will be 5 E1 connection from PBX to the 7206 at the h/q and 1 connection from PBX to the c3661 at the branches.
Can you help me with the configuration?
ciscomoderator
Community Manager
Community Manager
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
