08-27-2010 06:50 AM - edited 03-13-2019 07:06 PM
I have one 4-port FXO and one 2-port FXS on my 2811, so when I try to install the second 4-port FXO in the router, then 2-port FXS goes down.
Is there any way to make it work?
So I need two 4-port FXO and one 2-port FXS working on my 2811.
Any ideas?
Thanks.
Solved! Go to Solution.
08-27-2010 07:01 AM
Yep, there are insufficient DSPs to handle the 10 analog ports. The router only has a PVDM2-8 which only supports 8 ports.
PVDM Slot 1:
8-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
You'll need to add additional DSP resources to support the new ports.
-Felipe
08-27-2010 06:56 AM
sounds like there are insufficient DSPs installed in the router. can you provide the output of show diag.
-Felipe
08-27-2010 06:59 AM
Here is it:
GA11RR02#sh diag
Slot 0:
C2811 Motherboard with 2FE and integrated VPN Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time 00:19:21 ago
EEPROM contents at hardware discovery:
PCB Serial Number : FOC120409DX
Hardware Revision : 1.0
Top Assy. Part Number : 800-26920-04
Board Revision : A0
Deviation Number : 0
Fab Version : 04
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Processor type : 87
Hardware date code : 20080123
Chassis Serial Number : FHK1205F0LR
Chassis MAC Address : 001f.6c6d.f788
MAC Address block size : 24
CLEI Code : COM7R00ARA
Product (FRU) Number : CISCO2811
Part Number : 73-10258-05
Version Identifier : V05
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF C1 8B 46 4F 43 31 32 30 34 30 39 44 58 40
0x10: 03 E7 41 01 00 C0 46 03 20 00 69 28 04 42 41 30
0x20: 88 00 00 00 00 02 04 03 00 81 00 00 00 00 04 00
0x30: 09 87 83 01 32 65 FB C2 8B 46 48 4B 31 32 30 35
0x40: 46 30 4C 52 C3 06 00 1F 6C 6D F7 88 43 00 18 C6
0x50: 8A 43 4F 4D 37 52 30 30 41 52 41 CB 8F 43 49 53
0x60: 43 4F 32 38 31 31 20 20 20 20 20 20 82 49 28 12
0x70: 05 89 56 30 35 20 D9 02 40 C1 FF FF FF FF FF FF
PVDM Slot 1:
Hardware Revision : 4.0
Part Number : 73-8848-05
Board Revision : C0
Fab Version : 04
PCB Serial Number : FOC13230864
RMA History : 00
Processor type : 00
Product (FRU) Number : PVDM2-8
Version Identifier : V01
0x00: 04 FF 40 04 30 41 04 00 82 49 22 90 05 42 43 30
0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 33 32 33
0x20: 30 38 36 34 03 00 81 00 00 00 00 04 00 09 00 CB
0x30: 88 50 56 44 4D 32 2D 38 20 89 56 30 31 20 D9 02
0x40: 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 0:
2nd generation - FXO Voice daughter card (4 port)
Hardware Revision : 5.0
Top Assy. Part Number : 800-21589-04
Board Revision : A0
Deviation Number : 0-0
Fab Version : 04
PCB Serial Number : FOC11471L8L
RMA History : 00
Product (FRU) Number : VIC2-4FXO
Version Identifier : V03
CLEI Code : CNUIAXJAAB
0x00: 04 FF 40 00 4C 41 05 00 C0 46 03 20 00 54 55 04
0x10: 42 41 30 80 00 00 00 00 02 04 C1 8B 46 4F 43 31
0x20: 31 34 37 31 4C 38 4C 03 00 81 00 00 00 00 04 00
0x30: CB 89 56 49 43 32 2D 34 46 58 4F 89 56 30 33 20
0x40: C6 8A 43 4E 55 49 41 58 4A 41 41 42 FF FF FF FF
WIC Slot 1:
Board Revision : A0
Fab Version : 04
PCB Serial Number : FOC11471LL8
RMA History : 00
0x20: 31 34 37 31 4C 4C 38 03 00 81 00 00 00 00 04 00
WIC Slot 2:
2nd generation - FXS Voice daughter card (2 port)
Hardware Revision : 3.1
Top Assy. Part Number : 800-21341-01
Board Revision : E0
Fab Version : 01
PCB Serial Number : FOC0943279T
RMA History : 00
Product (FRU) Number : VIC2-2FXS=
0x00: 04 FF 40 00 47 41 03 01 C0 46 03 20 00 53 5D 01
0x10: 42 45 30 80 00 00 00 00 02 01 C1 8B 46 4F 43 30
0x20: 39 34 33 32 37 39 54 03 00 81 00 00 00 00 04 00
0x30: 89 56 00 00 00 FF FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
AIM Module in slot: 0
Service Engine AIM: 0
Top Assy. Part Number : 800-20063-06
Board Revision : B0
Fab Version : 05
PCB Serial Number : FOC12166CXV
RMA History : 00
Product (FRU) Number : AIM-CUE
0x00: 04 FF 40 03 8E 41 01 00 C0 46 03 20 00 4E 5F 06
0x10: 42 42 30 88 00 00 00 00 02 05 C1 8B 46 4F 43 31
0x20: 32 31 36 36 43 58 56 03 00 81 00 00 00 00 04 00
0x30: CB 87 41 49 4D 2D 43 55 45 89 56 30 33 20 FF FF
GA11RR02#
08-27-2010 07:01 AM
PVDM Slot 1:
-Felipe
