Folks,
I am configuring unity failover and need some assistance with callmanager configuration.
I have two line groups defined on the callmanager, linegroup1 and linegroup2. one if primary and the other if failover.
on the primary line group , i have all the calls being send to failover box if the primary does not answer or is not available.
On the secondary, i have for all ports forward to the next memeber without going to next group for all 3 senarious ( busy, not available, does not answer), am i right on this one?
also , how do i make sure that i do not running into any looping issues and reserver few ports to only dial out for MWI. Should i remove some ports from the group??? or make changes within a group.
