Unity max routing rules
mreilly
Does anyone know the maximum amount of routing rules that can be created for each table. I thought it was around 50
lindborg
I've created 70 or 80 in testing without a problem but I couldn't tell you what the realistic upper limit would be.
That said, there's usually a better approach to the problem at hand than creating a large number of routing rules - what is it you're trying to do?
Unity 7.02 / 200 ports / 4000 users - is there a maximum number of routing rules supported with this config?  We are currently trying to determine the best way to integrate several Avaya systems using PIMG and may need to use routing rules to do so....What are the overhead /considerations?
Thanks.
