08-22-2003 08:20 AM - edited 03-13-2019 01:18 AM
Is there a way to "boost" the volume of voice mail messages, especially when they are played over the sound card on a computer? Sometimes the messages are at such a low volume, I can't hear them even with the volume turned up completely.
Is this a Unity issue or a Call Manager issue?
Jessica
08-22-2003 08:22 AM
By the way, we are running with CM version 3.2(2c) and Unity UM version 3.1(5)
08-22-2003 09:47 AM
You can either use the WavGain or SetVolume utilities on Jeff's site.
http://www.ciscounitytools.com/App_WAVGain.htm
http://www.ciscounitytools.com/App_SetVolume.htm
You should use use the WavGain utility to set those two registry keys to 0, and then use the SetVolume utility to tweak the audio until it's a desirable volume.
adam
