Dear support, I want to make a Qos of voice over frame relay ( 4 sites connected point -to - multipoint 256 kbps at main and 64 kbps for the three other sites )using routers 1601 and 805..
I want to configure the Following:
1-LLQ
2-Frame Relay traffic shaping
3-FR.12
4-cRTP.
Does the Qos of voice is supported by the image file "IP" or "IP Plus" ?
Does the Router 805 with IOS 12.2 (3) supports these features of Qos of Voice over frame relay ?
What is the suitable IOS for the 1601 that supports these four features of Qos of Voice over frame-relay and what is memory requirements on the 1601 for that??
Pleae advice as soon as possible , waiting for your answer to these questions.
