Using variable nodes in script editor...
jackmach33
Community Member
I have read some documentation that indicates that the pv1-10 variables can hold multiple values using the parameter seperator. Is this something that can be in icm scripts created in script editor, e.g. if a|b, then go here, if a|c, then go here? I am wondering because in our system we are in need of additional variables to utilize in scripts. Thanks.
Chris Deren
If you need additional variables, you can define Expended Variables in ICM, you can reference them in IP-IVR just fine. I am using a lot of them.
Please rate all usefult posts!
Chris
