ValCom Paging System
gmgarrian
Level 4
Level 4
Has anyone setup a single zone ValCom paging system to work with an h323 gateway?  I was told by ValCom to use an FXO port according to the ValCom procedure I've attached to this post.
Dialing the extension causes the lights on the FXO to light up, so I'm assuming all is well on the CUCM side but paging is still not working.  At this point I'm trying to rule out an issue with the Cisco side of things.
Craig Dyer
Level 3
Level 3
          I would suggest that you connect a POTS analogue phone to the ValCom paging system, if you take the phone off hook and press 0,1,2 or 3 you should select a zone to page.
          If that works then we can look at the CUCM.
Craig
