VG450 compatibility with Ziztel PAGA system.
Translator
Community Manager
Community Manager
The VG450 unit is compatible with telephone input to the PAGA system? It is an industry standard 2 wire analog subscriber line POTS.
If yes, what is the suggested configuration to be done on the VG450?
Jonathan Schulenberg
It’s unclear what is on the other side of the VG450 here; I will assume CUCM with an MGCP or SCCP registration.
https://www.cisco.com/c/en/us/support/docs/voice/media-gateway-control-protocol-mgcp/214635-configure-and-troubleshoot-mgcp-gateways.html
In either scenario you need to know whether this PAGA system wants line start or ground start signaling. Presumably it expects an FXS port since you selected a VG450. Some paging systems want an FXO port instead - so check their documentation.
